Total
175
products in category of
LED Light
Sort by:
Importance
Show:
30 items
![]() LED pendant lamp 2011-04-02 10:50:08 LED PENDANT LIGHT, LED LIGHT, LED LAMP, PENDANT LIGHTS 1. Item:MD8002-S2.Material:glass+crystal+metals3.Size:35*35*100 cm4. CE APPROVED5. Lead time 20-30 day ... www.chandelier-lamp-b2b.com [China]
![]() Led table Lamp 2011-04-02 10:50:08 LED DOWN LIGHT, LED LIGHT, LED LAMP,LED TABLE LAMP 1. Item:(MT8001) 2.Material:aluminum+crystal+metals 3.Size:28*28*46cm 4. CE APPROVED 5. OEM Service is available Pr ... www.chandelier-lamp-b2b.com [China]
![]() Chandelier Lighting 2011-04-02 10:50:08 Chandelier Lighting 1, Material: Dewaxing Iron 2, Crystal: Chinese (A class) 3, Antique painting 4, Size:101*101*94cm 5, Chandelier Lighting with 10 lights www.chandelier-lamp-b2b.com [China]
![]() Emergency Light 2011-04-02 10:50:08 Emergency Light 1. Description: 6V4.0Ah 2. Rechargeable Sealed Lead-Acid Battery 3. 1X9 ... www.chandelier-lamp-b2b.com [China]
![]() LED Lamp 2011-04-02 10:50:08 LED lamp 1.With 1W x 4pcs LEDs Light Source, Made of Iron and Aluminum 2.AC: 100 to 240V 3.Frequency: 50 to 60Hz 4.DC: 14V/350mA 5.LED light source: 1W x 4pcs 6.C ... www.chandelier-lamp-b2b.com [China]
![]() LED Light 2011-04-02 10:50:08 LED Light 1.AC:100~240V 2.Hz:50Hz~60Hz 3.DC:22V/350mA 4.LED/ 90pcs*0.06W 5.TC:4800K & ... www.chandelier-lamp-b2b.com [China]
![]() LED Lights 2009-12-08 10:12:22 W6032H Brush Power: 6 x 1W LED Finish: Varnished after brushing The lamp body is made of pure aluminum and is molded through extrusion, and ... www.interior-exterior-lights.com [China]
![]() LED Lights 2009-12-08 10:12:22 W6029H Brush Power: 6x1W LED Finish: Varnished after brushing The lamp body is made of pure aluminum and is molded through extrusion, and then sha ... www.interior-exterior-lights.com [China]
![]() LED Lights 2009-12-08 10:12:22 W6019H Brush Power:2x3W LED Finish: Varnished after brushing The lamp body is made of pure aluminum and is molded through extrusion, and the ... www.interior-exterior-lights.com [China]
![]() LED Lights 2009-12-08 10:12:22 W6013H Brush Power: 4 x 1W LED Finish: Varnished after brushing The lamp body is made of pure aluminum and is molded through extrusion, and ... www.interior-exterior-lights.com [China]
![]() LED Lights 2009-12-08 10:12:22 W6008H Brush Power: 2 x 3W LED Finish: Varnished after brushing The lamp is made of pure aluminum and is molded through extrusion, and then shaped ... www.interior-exterior-lights.com [China]
![]() LED Lights 2009-12-08 10:12:22 W6004H Brush Power: 2x 3W LED Finish: Varnished after brushing The lamp body is made of pure aluminum and is molded through extrusion, and t ... www.interior-exterior-lights.com [China]
![]() LED Lights 2009-12-08 10:12:22 R6018H Brush Power: 1x 3W LED Finish: Varnished after brushing The lamp body is made of pure aluminum and is molded through extrusion, and then sha ... www.interior-exterior-lights.com [China]
![]() LED Lights 2009-12-08 10:12:22 R6011H Brush Power: 1x 3W LED Finish: Varnished after brushing The lamp body is made of pure aluminum and is molded through extrusion, and then sha ... www.interior-exterior-lights.com [China]
![]() Power LED Flashlight 2010-09-26 09:09:46 Power LED flashlight Package: White box/ Blister Cards QTY: 96pcs/ CTN Carton size: 58x32x38cm Item size: 42x(L)133mm Operated by 3AAA battery Suitable for indoor and ... www.flashlights-led.com [China]
![]() Auto Lamp 2010-08-14 17:38:57 1. T15-wedge: 9LED, 3-tier 15LED 2. T13-wedge: 6LED 3. T13-wedge: 5LED - piranha led + side facing 4LED 4. T11-wedge: 4LED 5. LED type: dome L ... www.led-auto-bulbs.com [Taiwan]
![]() Auto Lamp 2010-08-14 17:38:57 1. 3156: single contact 2. 3157: double contact 3. QTY of LED: 12LED, 19LED,2-tier 18LED,2-tier 24LED 13pc & 19pc piranha LED 4. LED type: dome LED, flat ... www.led-auto-bulbs.com [Taiwan]
![]() Led Light Bulb 2010-08-14 17:38:57 1. BASE: BA9S, E10 2. QTY of LED: single LED, 4LED, 5LED piranha+4LED in side facing 3. LED type: dome LED,flat LED, concave LED, piranha LED in water clear or wh ... www.led-auto-bulbs.com [Taiwan]
![]() Led Light Bulb 2010-08-14 17:38:57 Feature: 1. BASE: BA9S, E10 2. QTY of LED: single LED, 4LED, 5LED piranha+4LED in side facing 3. LED type: dome LED,flat LED, concave LED, piranha LED in water c ... www.led-auto-bulbs.com [Taiwan]
![]() Auto Lamp 2010-08-14 17:38:57 1. 3156: single contact 2. 3157: double contact 3. QTY of LED: 12LED, 19LED,2-tier 18LED,2-tier 24LED 13pc & 19pc piranha LED 4. LED type: dome LED, flat LE ... www.led-auto-bulbs.com [Taiwan]
![]() Auto Lamp 2010-08-14 17:38:57 1. 7440: single contact 2. 7443: double contact 3. QTY of LED: 12LED, 2-tier 15LED 4. LED type: dome LED, flat LED in water clear or white diffused 5. Voltage ... www.led-auto-bulbs.com [Taiwan]
![]() Auto Lamp 2010-08-14 17:38:57 LED Auto Lamp Features: T15-wedge, T13-wedge, T11-wedge LED auto bulb Model: LW15, LW13, LW11 1. T15-wedge: 9LED, 3-tier 15LED 2. T13-wedge: 6LED 3. T13-wedge: ... www.led-auto-bulbs.com [Taiwan]
![]() Auto Bulb 2010-08-14 17:38:57 Filament Lamp Features: T10-WEDGE filament auto bulb, indicator lamps WEDGE: single contact color: clear, dyed color: red, amber, blue, green, purple natural glas ... www.led-auto-bulbs.com [Taiwan]
![]() LED Bulb 2010-08-14 17:38:57 Wedge Base Features: 3156/3157 T25-wedge LED auto bulb Model: LW25 1. 3156: single contact 2. 3157: double contact 3. QTY of LED: 12LED, 19LED,2-tier 18LED,2-t ... www.led-auto-bulbs.com [Taiwan]
![]() LED Bulb 2010-08-14 17:38:57 Wedge Base Features: T15-wedge, T13-wedge, T11-wedge LED auto bulb Model: LW15, LW13, LW11 1. T15-wedge: 9LED, 3-tier 15LED 2. T13-wedge: 6LED 3. T13-wedge: ... www.led-auto-bulbs.com [Taiwan]
![]() LED Bulb 2010-08-14 17:38:57 Wedge Base Features: 7440/7443 T20-wedge LED auto bulb Model: LW20 1. 7440: single contact 2. 7443: double contact 3. QTY of LED: 12LED, 2-tier 15LED 4. LE ... www.led-auto-bulbs.com [Taiwan]
![]() LED Bulb 2010-08-14 17:38:57 Wedge Base Features: T11-wedge, T10-wedge, T8-wedge, T5-wedge LED auto bulb Model: LW11, LW10, LW8, LW5 1. T11-wedge: piranha LED 2. T10-we ... www.led-auto-bulbs.com [Taiwan]
Related Catalogs Of LED Light |
We are the leading manufacturers providing a quality range of LED Light. Our company is backed by superior and advanced manufacturing techniques to offer impeccable quality products to our clients. Owing to our client centric approach, we offer quality products at industry leading prices and ensure to deliver the ordered consignments within the stipulated time frame. Good quality, reasonable price and the 5-Star service are guaranteed.
